Suspension & Brakes Theory, alignment, spring rates....
11in Rotor on an EX
Old Sep 22, 2010 | 11:46 AM
1.5Slowmatic's Avatar
Default 11in Rotor on an EX
I have a 2000 EX so i already have 10.3in fronts. Now my question is can i use an 11in rotor without modding? i know fastbrakes makes the kit for cars with smaller rotors to use the 11in piece but i have found nothing. i ask because i was planning to run VW coraddo rotors since they are 11in and 4x100 and can get them CHEAP so its not like it isn't worth it.
Old Sep 22, 2010 | 12:05 PM
jr_deleon's Avatar
Default Re: 11in Rotor on an EX
Are you trying to use 11in rotors with the stock calipers? That what it seems like you want to do. Unless you have an 11in adapter kit (like the one fastbrakes makes) you'll need to get the brackets that correspond to the rotor size. The 23T/25T/28T brackets will all work, but its the 23T (ITR) ones you want as you wont have to mill anything.
Try looking at the Integra kits on fastbrakes as they are the same size as your EX. Ive noticed before on that site that kits that would fit a Civic EX arent available under the Civic tab but are available under the 94-01 Integra.
Old Sep 22, 2010 | 06:25 PM
ahhh did not think of that. i will check that out thanks
Old Sep 23, 2010 | 04:09 PM
ok so nothing on fastbrakes about using an 11in rotor with stock calipers. i caught a glimpse of something about modded ITR rotors but thats it. Does anyone know if this can be done or not?
Old Sep 23, 2010 | 06:09 PM
jr_deleon's Avatar
I dont know what happened with the site. They used to have many 11in OEM caliper kits that were a lot less than 600. Maybe ask him on the phone. Years ago i talked to him before he even started posting prices on the ITR front mods and he had them, so its likely he has something there that isnt posted on the site. Try him you'll see
lkell15
Aug 28, 2013 06:10 AM
turboblack2door
Jul 1, 2008 03:48 AM
revhigh96
44
Jun 21, 2004 11:22 AM
Jonathan_ED3
15
Apr 1, 2004 09:27 AM
Racebrewer
Mar 11, 2002 03:23 PM
