Help! Installing OEM Navigation unit in 08 civic (what is exactly needed?)
I am piecing together all the parts to covert my car from having the oem cd player to the oem navigation. I am coming across different part numbers for the navigation units. I have a 08 civic ex. Does anyone know if any 06-10 navigation unit will work in the 08? Meaning out of the si or another ex? Researching into it I dont think I can get away with the hybrid civic navigation, but it looks like the ex or si will work. Anyone have any help or advice?
Thanks in advance
Thanks in advance
Im not sure, but I think you need more than just nav unit, you need the nav module too, it goes in the trunk and wiring, its a very problem that uppgrade
good look :D
good look :D
Thanks in advance
Thanks in advance
I'm in a similar position. I have a 2007 EX Sedan with OEM cd/am/fm/xm radio and want to install OEM navigation unit.
Please forward me anything you might have on how, where, what to do etc.
thx
Not sure about the link posting rules so I took an excerpt but if you do a search (user:nighthawksi) on the other site mentioned theres a thread which has these parts listed:
good luck
1. oem navi (gun metallic) 39540-sva-a00za
oem navi (taupe gun metallic) 39540-sva-a00zb
2006-2007 SI coupe navi will also work
2. GPS ant. Assembly 39835-sna-a01 $23.62
3. Navi bracket (drivers side) 77256-sna-a00 $1.72
4. Navi bracket (pass. Side) 77255-sna-a00 $1.72
5. Navi dash panel (gun metallic) 77250-sna-a01za $23.50
(taupe gun mettalic) 77250-sna-a01zb $23.50
6. Bracket – navi bolt 91551-se0-003 $0.78 (8)
7. Bracket/dash panel bolt 93913-14420 $0.32 (4)
8. Bracket bottom bolt 90133-sm4-003 $2.25 (2)
9. Instrument panel harness 32117-sva-a31 (auto trans) $198.31
32117-sva-a30 (5spd) $198.31
10. Harness ground bolts 90148-se0-003 $2.91 (7) – optional(re-use old)
11. Microphone/sunroof harness 32156-sva-a11 $58.81
12. Navi microphone 39182-sna-003 $69.28
13. Microphone screw 35151-sna-003 $0.08
14. Rear steering wheel garnish 78518-sva-a31za $38.86
15. Front steering wheel garnish 78540-sva-a31za $41.66
16. talk/back switch bracket 78517-sva-a31 $12.64
17. talk/back bracket screw 93913-24420 $0.32
18. talk/back switch 35890-sva-a01 $40.91
19. Switch screw 90173-sva-a02 $5.85
20. Switch screw 90178-sna-a81 $5.94 (2)
21. Cruise/audio buttons 36770-sva-a22 $72.10
sedan should use these part #'s instead
1. oem navi (gun metallic) 39543-sna-a01za
oem navi (taupe gun metallic) 39543-sna-a01zb
Did you ever find that info on how to upgrade to navigation in your car.
thx
thx
I followed everything I could find off of 8th gen civic. Now I just need help wiring together the navi microphone talk back and the two steering wheel buttons. But everything else works great...
After doing the OEM swap I would probably just buy an after-market unit with DVD ect. However, if you do stick to oem make sure you either use the premium if you already have a premium stock stereo or the non-premium navigation unit if you have a non-premium unit. Best bet is to find a crashed car to pull everything out you need. I was successful installing the 06 Navi unit into an 08 civic, lots of work, but it works great. Good luck.
I've searched these forums and several others, but cannot find anyone who has done a step by step "instruction" for replacing a non-navi 2006 HCH with an aftermarket Kenwood/Pioneer double din in an OEM dash kit. Does anybody here have the step by step on upgrading from the OEM CD player to an aftermarket or OEM navi? A video would be even better.
Thanks,
Ken
Thanks,
Ken
Aftermarket NAV radio won't work in a OEM double din dash... You need to get either the Metra or Scosche kit.
Does anyone have any info for programming oem navigation unit on a 2007 Honda Civic?
The buttons for the sat/nav aren't working, So unable to use it. But everything else seems to work. Dealer wants $$$ for programming according to them that will fix issue. Appreciate your guys help. Maybe some tsb or any kind of info from service manuals? Thanks again guys.
kroze
Audio / Security / Video
May 25, 2008 04:36 PM
SoullessJapaneseMachine
Oct 23, 2006 04:26 PM
Thirty-Nine
Apr 8, 2005 08:01 AM
08, 2008, accord, civic, honda, hybrid, instalation, install, installing, nav, navi, navigation, oem, putting, si
