OBX THROTTLE BODY
Anybody rock an OBX throttle body?
If so can you share some feed back on it.
I'm looking at a 74mm one on ebay an it's less then $200 new.
Compared to Skunk2 70mm throttle body that cost extremely close to $400!
**** that.
http://cgi.ebay.com/ebaymotors/ws/eB...5359&viewitem=
**** that.
I generally agree with what Russ is saying but I must say that there are certain parts that OBX makes that are far superior to stuff that is on the market. I know their RH was pretty good and also their lsd's. They also had the mugen replica twinloop that were very good quality... but the rest of their stuff I would personally stay away from!
hybrid racing TB looks top!
The Hybrid Racing throttle body is over $400!
There's also Blox & BDL that make tb's
Little cheaper, but i know nothing of they're reliability.
Why are these parts so damn expensive if they only work right after a certain peak in power?
i ran a bdl on a car.. worked just fine., im not a huge obx fan.. their race headers were a decent buy tho.. buddy club sounds like sex when paired up with a skunk2 60 cat back
you gotta pay to play homie
iv known a few people use them. they work fine.
def dont stick like the BDL tb.
although the HR is nice but high $. and you cant take the cruise control off of it, only teh bracket part which is lame.
Thanks.
I'm going max bore maxbore. This is what someone got on EPhatch.
I'm using a blox 74mm tb on my car right now! Is pretty good I feel more torque and feel that my high-end has improve. But I just can't figure you how to fix my idle because is idling at 2000rpm. :[
taper created velocity and to be honest tb's aren't going to get you anything at all unless your motor is exceeding the amount of flow it already has. so tb on a bolt on motor build is a waste. putting a velocity stack on your intake pipe has more of an effect.
Well im building a K20Z1 turbo, shootin for 370-400whp
kinda useless.. turbo gona be punching air thru there.. i never replace the stock tb when building anything less than 500whp goal, and typical don't replace it ever to be honest. ill put a bored and tapered unit on a na car to help because the engine is creating suction to pull in air rather than a turbo thats going to push air in no matter what.
I've been told going 100hp over stock is when it actually makes a difference.
