Classic Hondas All Pre-1988 Hondas.
s600 suspension upgrades??
Old Sep 21, 2010 | 09:21 PM
dlordco's Avatar
Default s600 suspension upgrades??
looking for some advice from the pro's out there
im building a s600 with a bout 3 times the original power. what would you suggest i use for suspension . i got the car without any rear suspenion and im contemplating using a miata rear subframe and just shortening it ( miata is 10 inches wider at the brakes)
i toyed with using a miata front subframe but its also 10 inches wider and not as easy to shorten as the rear would be. should i just upgrade the control arms and add a coilover shock?
thanks in advance
Old Nov 14, 2011 | 04:45 PM
Peter Davis's Avatar
Default Re: s600 suspension upgrades??
What motor were you thinking of? Did anyone provide any help with suspension/brakes?
Halo
Honda Fit
15
Mar 8, 2006 11:23 AM
slowcivic
Apr 17, 2003 10:04 AM
SohcVtecCrix
Feb 10, 2003 07:10 AM
