1991 awd pore mans type r motor swap help
Old Sep 21, 2010 | 08:27 PM
browntown jdm's Avatar
Default 1991 awd pore mans type r motor swap help
i just picked up a 1991 honda civic awd in perfect condition for $300 with clean title. im currently building a poor mans type r that im going to throw in the car. i know it wont be a awd anymore after i do the swap but i think it will still be sick as hell. noone would expect that thing to ripp. its going to be my first build and im just curious of what i need to do to it to make the swap happen. like ecu? if i have to compleatly switch out the wireing harness to work on my obd1 motor? what axles do i have to use, cuz i been hearin people that do motor swaps have problems with axles fallin out or somethin. stock motor is a d16y6
WHAT DO I NEED TO MAKE MY CAR A DRIVER!!!!!!!
so far i got
82mm gsr block
ls crank
crower rods
82mm hi comp pistons
port n polish jdm b16 head with gsr cams
port matched type r intake
Old Sep 21, 2010 | 09:44 PM
littlewagon's Avatar
Default Re: 1991 awd pore mans type r motor swap help
Did a similar swap on one of my wagons. Pretty much the same as any other B series swap into an EF.
I used my existing DX dpfi wiring harness and OBD1 GSR wiring harness to make the needed wiring harness. First you need to convert to mpfi and then to OBD1. You will also require a OBD-0 to OBD-1 jumper harness. I used a P72 GSR ecu but a P28 sohc vtec ecu will also work since you will require some sort of chipped/programmable ecu for tuning anyway. In addition to the B series motor you already have you will need a B series trans,EF swap specific mounts such as Hasport /Innovative, shortened B series shift linkage and 90-93 Integra axles w/intermediate shaft. Some people have also used 94-95 Integra axles and intermediate shaft. Also 90-93 Integra rear trans mount bracket. Good luck.
Old Sep 22, 2010 | 04:08 PM
hey man thanks alot. i also need some help with what size of injectors to use???
Old Sep 22, 2010 | 04:31 PM
D16SiHatch's Avatar
stock injectors would probably be fine. if you want to play it safe then maybe go with some 330cc units.
and this should answer some of your questions
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Sep 22, 2010 | 05:07 PM
sh!ft's Avatar
Who the fack changed my title?!
wouldnt a b20 awd trans work for this platform as well??
Old Sep 22, 2010 | 06:23 PM
i want to make this swap as easy as possible if thats possible lol. i dont think im going to keep it a awd. thank you for input and the thread. it helped tons
Old Sep 22, 2010 | 06:41 PM
beansandrice's Avatar
Damn! Those old school AWD trannys were nutts strong bro. The newer B series AWD are weaker than the oldies. I would just do z6 turbo awd. But I built a PMTR engine in my last EF 190hp.
I was happy I ran pr3 pistons ITR cams B16 head I ported/polished, GSR dual intake springs on the Exhaust side and some other goodies
Old Sep 23, 2010 | 09:53 PM
~sp33~'s Avatar
EFB055
No.
Hate seeing people swapping out the awd systems to put in B series. Such a waste.
Old Sep 23, 2010 | 10:19 PM
Bludger's Avatar
Originally Posted by ~sp33~
No.
i'm sure there are those that hate you showing off your car.....
each to their own
if you hate, don't post......
bye
Old Sep 23, 2010 | 11:33 PM
~sp33~'s Avatar
EFB055
each to their own
bye
Why not buy a cheaper and easier to swap front wheel drive chassis? You could probably sell the rt4wd wagon to someone who appreciates it, buy 2 front wheel drive wagons with the profit and have an easier swap on your hands.
Makes no sense.
Old Sep 24, 2010 | 03:33 AM
im with sp33. The SOHC awd system is awesome.
Old Sep 24, 2010 | 04:37 AM
Bludger's Avatar
ok, I'm sorry.
I thought the Op was going to continue with the awd setup.
have now read that he wants to ditch the idea and wants to run FWD setup.
what a waste.
can't hate you for it though, just don't agree with what you're doing.
they are rare as setup the awd Civic (well at least its rare here in AU) so its such a waste.
still can't hate you for it though
lol
Old Sep 24, 2010 | 05:19 AM
~sp33~'s Avatar
EFB055
ok, I'm sorry.
Did you not read my first response? I was wondering why your reply made no sense.
Old Sep 24, 2010 | 01:08 PM
that makes alot of sence to just keep it a awd since there arent many around. i think im just going to do that with this one and get another fwd car for cheap like i did with this one. i mean hell. there are tons of cars out there that are nice and cheap. i got my awd for $300 and its clean as hell.
thanks for knockin some sence in me haha
Old Sep 24, 2010 | 01:10 PM
but my idea for this car was to put my b swap in it and make it a totle sleeper car that would be funny to see peoples reaction.
Old Sep 24, 2010 | 02:31 PM
B to D adaptor Go to bisimoto.com and give them a holla! The ring gear in the SOHC awd trans is way beefier than the b20's
Old Sep 24, 2010 | 07:39 PM
myelinsheath's Avatar
b series does not equal instant awesome-ness as most people seem to suggest.
Old Sep 24, 2010 | 07:56 PM
DumpdEJ6's Avatar
I like the tuna here
This thread is worthless without pics.
Old Sep 24, 2010 | 09:23 PM
I have seen a couple of AWD wagons swapped w/B-series motors and using the AWD trans from the first gen CRVs. Does require some fabrication as the transmission mounts differently to the frame rail.
Old Sep 25, 2010 | 01:11 AM
~sp33~'s Avatar
EFB055
The front and rear differentials also have different ratios, so you'll have to use the CRV rear end, which doesn't mount the same as the wagon rear end. Headache.
I heard the adapter plate doesn't clear the transmission?
Old Sep 25, 2010 | 05:13 AM
really? engineering fail. d series ftw
Pudge1421
K Series
Apr 16, 2018 05:23 AM
eghondafamily
Aug 11, 2006 11:28 AM
tatted91rex
Feb 16, 2006 10:30 PM
bryanb2
Nov 18, 2004 04:43 AM
