99 prelude h22 jdm swap problem starting
Old Sep 21, 2010 | 04:12 PM
bungdogjb's Avatar
Default 99 prelude h22 jdm swap problem starting
i have a 99 prelude automatic that i put a h22 jdm swap in. The old engine had two sensors on the crank and the new engine doen't have them sensors. the jdm engine came with an internal coil dizzy the old one was external. I used the old wiring harness and the external coil dizzy. since the bastards cut the wiring harness that came with the jdm engine instead of unpluging it. Now i'm having trouble, it has no spark and i'm sure it has something to do with them two sensors on the crank not being there. can i bybass them? or trick them? i've done a bypass with the b series engines before, for the crank sensor but i think that was and obd1 and obd2 issue. My current problem might be a jdm vs usdm issue i think. I couldn't find my exact problem on the search page. so any info or help will be great.
rekserjdm
Sep 25, 2014 06:48 PM
Yannx13
Nov 19, 2013 05:28 AM
HelpmyH22
Jun 21, 2010 09:04 AM
God-Driven
Mar 21, 2007 12:14 PM
