Need ITR Bearing Chart!!!!! Please!!
Just removed Stock ITR rods and Pistons and I am unable to read the bearing color on any of the bearings.
The number "24" is stamped on all the rods and the letter "X" is stamped on the crank rod journals.
What bearing Does ITR bearing chart recommend for those two codes?
Any help greatly appreciated
Thank you so much for the Bearing chart.
Last question: Is the main bearing chart for the type r
B18C5 engine the same chart as a B18C1?
In the Helm manual, only the connecting rod bearings had a separate chart for the B18C5. The main bearing chart is for all USDM Integra engines (in 1998).
