battery light comes on and off.
am a problem well not yet i just wanna make sure it is the alternator messing up on me and nothing else. so my battery dash light turns on when my cars at idle but then it turns off when i start going or revv it. i measured the battery voltage while the car was on and it read like 9V. and while its off its like berely even 12.2V. it runs fine it does feel like a loss of power thought. is it the alternator for sure or could it be something else???
lol!!! dood its your alternator..thats pretty much the purpose of that batt light. its on at idle cause the alt. isnt charging as it should. goes off as you drive cause it spins faster and starts to work again. 9v is a bit low for it to be charging... replace your alternator!!
got it!!! replaced my alternator. and working good but i tried taking it out through the top couldnt fit so i took out the master clinder and air got into my brakes. so i need to bleed em out. eventually i took out the alternator through the bottom. simple procedure if u know what you are doing.
KiTTyOnRoiDs
Acura TL, RL & ZDX
Jun 11, 2015 12:53 PM
