its shaky
Old Sep 21, 2010 | 10:53 AM
jager_bomb_79's Avatar
Default its shaky
ive been feeling a shaking in my front wheeles for awhile now. i just put new shocks and struts on this weekend and that didnt solve the problum but it does ride alot smoother tho. execpt for the wobble. i was just wondering if anyone know what the next thing i fix should be.... all of it, lol. gotta love these 89's.
Old Sep 21, 2010 | 10:58 AM
chafetzk's Avatar
Default Re: its shaky
get your tires balanced and get an alignment
Old Sep 21, 2010 | 11:04 AM
DCRB's Avatar
start off by rotating your front tires to the rear. if the shake goes away then it is tire/wheel related. you should take your wheels to be balanced and examined for possible damage. I had a tire that the belts broke inside of it and caused the inside edge to randomly bulge out, causing a vibration.
if the front is still "shaky," start off by jacking the front the vehicle up, grasp your front wheel at the 9 and 3 o'clock positions and try push/pull it towards/away from you (you'll get what i'm saying when you do it). then grab at the 12 and 6 o'clock position and do the same thing. if you have excessive play, you should have your wheel bearings looked at, and possibly replaced as they may be worn out
Old Sep 21, 2010 | 03:53 PM
hatchet_honda's Avatar
this shoulda been the first thing to be checked....
Old Sep 21, 2010 | 04:53 PM
Oedwards's Avatar
I had this problem when I bought my 90 sedan. I will tell you everything I have replaced, it may help you. I am not saying replace these, this is just what helped me..
Passenger axle and bearing
Strut rod bushings
I found lots of loose bolts.. i'm hoping from age and not the guy who did the work on it..
the univeral joint on my steering column was loose..
My shake is way better but I still have a slight vibration.. I have narrowed it down to a bent rim though.
Old Sep 21, 2010 | 06:08 PM
blasterman87's Avatar
if the shake is at all speeds it could be bent rim/bad axle. if it shakes around 50-60 then its a wheel out of balance. allignment wont make it shake.
bfinger35
Apr 13, 2016 06:26 AM
exz0n-.-
Nov 27, 2008 12:19 AM
jaycetan
Mar 23, 2005 08:54 PM
performula
12
Sep 11, 2002 07:49 PM
Rain_man
Jul 15, 2001 12:10 PM
