ctr pistons in ls
Old Sep 20, 2010 | 08:42 PM
kicken90crxsi's Avatar
Default ctr pistons in ls
was curious what would be the compression ratio in a b18a1 with ctr pistons with 404 cams will be claying it just curious if anyone can help me out sorry if this question been asked before
Old Sep 21, 2010 | 07:28 AM
midnighteg-6's Avatar
Default Re: ctr pistons in ls
it will depend on what head you trow in it but it will be around 12:3 with ls head and around 12:6 with a gsr head also depends on your head gasket too will definetly recomend claying it.
Old Sep 21, 2010 | 11:43 AM
it will be a p75 ls head will definatly clay it for sure the reason why im asking is that on the zeal autowerks compression calaculater it says itll be 13.2 to 1 in a ls motor
Old Sep 21, 2010 | 02:25 PM
00Red_SiR's Avatar
All Motor Mentor
Roughly 12.3:1 assuming you run a 3 layer (stock) headgasket, no decking or milling.
Old Sep 21, 2010 | 02:27 PM
gixxerboy750's Avatar
x2
Old Sep 21, 2010 | 04:58 PM
thank u guys so much sounds good will be a 3 layer head gasket and unless my head is warped no milling or decking but i know its fine will check for 100 percent of course
bakomack
Jul 18, 2010 10:37 PM
B Dap
Apr 22, 2010 01:38 PM
cisurfer1
Feb 20, 2006 08:31 PM
ek9jdm
Apr 7, 2004 05:14 PM
JDubya
Feb 21, 2003 09:56 AM
