DPFI to MPFI question. Z6 I.M. on D15b2 head?
Old Sep 20, 2010 | 01:40 PM
alex14's Avatar
Default DPFI to MPFI question. Z6 I.M. on D15b2 head?
I have a full D16Z6 motor that I plan on rebuilding. I'd like to know what all i would need to do a MPFI swap using the Z6 Intake manifold.
1. Is the Z6 manifold compatible with the D15b2 head?
2. Is there a link to the MPFI re-wiring would I have to do?
3. Would I need another ECU or could I run the PM5?
4. Is there I write up anywhere for this specific combination? (i've searched, no luck)
Any help is appreciated.
Old Sep 20, 2010 | 01:45 PM
D16SiHatch's Avatar
Default Re: DPFI to MPFI question. Z6 I.M. on D15b2 head?
1. yes
2. eh?
3. yes you need a mpfi ecu, no to the pm5
4. for the specific combo, i don't know. but the conversion is virtually the same no matter what mpfi manifold you use
http://hondaswap.com/swap-articles/d...writeup-49557/
tx_ej8_49's Avatar
Step 1. Remove harness
Step 2. Send me your harness and i will convert it for you
Step 3. Once you receive the harness back, install the harness per detailed instructions.
Step 4. Enjoy!
Oh i have a few pm6's i can sell you for uber cheap.
Old Sep 20, 2010 | 02:13 PM
alex14's Avatar
Originally Posted by D16SiHatch
1. yes
2. eh?
2.(I need to proof read. Edited.)
what ECU will I need (I assume PM6)
is there any one manifold thats better than the other? (A6, Z6, y8?)
Step 4. Enjoy!
If I paid you to do it, I wouldnt learn anything now would I?
Old Sep 21, 2010 | 11:33 AM
D16SiHatch's Avatar
in this order y8>z6>a6 , lol
the z6 is a decent bit better, and the y8 has been called the "type r" of d-series intake manifolds.
Old Sep 21, 2010 | 11:35 AM
alex14's Avatar
Thanks man. I've done a bit more research and I might as well wait to swap in my D16z6 rather than put anymore energy into the D15.
Thanks guys.
Old Sep 25, 2010 | 08:18 PM
89 rex's Avatar
Hi i am doing the same swap to my d15b2 converting it to mpfi and got a question about it. For the harness do i have to use the harness or can i use a different harness that already has the mpfi as long as it aint vtec and obd0?
JRZ88DX
Mar 10, 2010 08:20 PM
CRXguy_88
11
Mar 1, 2010 03:47 AM
spens 91 Ef
30
Mar 18, 2009 02:38 AM
Drew17th
Jun 1, 2006 07:18 AM
Jeff_G
Sep 8, 2002 04:48 AM
