92 integra broken tensioner bolt in the block! Help!!
Old Sep 20, 2010 | 01:14 PM
ek4_sir's Avatar
Default 92 integra broken tensioner bolt in the block! Help!!
I have a 92 Integra with a tension pulley bolt for the timing belt that broke. When removing the bolt it very tight but was slowly caming out. While backing the bolt out the bolt snapped with a quarter of the thread stuck in the block.
Is there any way of removing this bolt without having to pull the motor out? Please help!! All that is left is exposing is roughly the thickness of a dime.
Thanks in Advance for your responses!
Old Sep 20, 2010 | 01:43 PM
96ej8MR's Avatar
Default Re: 92 integra broken tensioner bolt in the block! Help!!
Try taking it to a shop, or if there is any threads that you can grab with some needle nose vice grips, try to spin it out.
Old Sep 20, 2010 | 03:29 PM
vrrodri's Avatar
Probably not enough room there to use a bolt extractor bit...spray the area with PB Blaster and let it sit for two hours then if you can grab the tip with locking pliers try twisting it out.
Old Sep 20, 2010 | 05:22 PM
ek4_sir's Avatar
tried both ideas and it didnt work.. been working on it for about 2 weeks now... completely out of ideas now.. All that is left is pulling the motor...
Old Sep 21, 2010 | 09:22 AM
vrrodri's Avatar
Did you try using a torch to heat the area pretty good then trying to twist it out?
Old Sep 21, 2010 | 10:47 AM
yeahyeah1469's Avatar
torch it out the bolt cant handle the heat but the block can .. it will mely out like butter but have shop do it or you can scorch the threads and makes it harded to put a bolt back in
Old Sep 22, 2010 | 09:33 AM
ek4_sir's Avatar
Thanks for the help. I'll give it a shot!
vaspeeder
Jun 19, 2009 10:25 PM
D_CRX_Si
Mar 10, 2006 10:42 AM
XDEep
Sep 18, 2004 09:37 PM
Renegade
15
Sep 22, 2003 06:28 AM
hellas
Jan 21, 2003 12:33 PM
