FS: 95 B18B1 107k Miles
Just swapped in a JDM B18C into my ls so no longer need my old engine. There is nothing wrong with it, runs perfectly fine. I just wanted more power. It has 107k original miles. Does not burn any oil, but does leak a small amount from corner of valve cover. Needs new valve cover gaskets. Also a small amount from the distributor but i will include a new o-ring to fix that. Swap comes with engine, ecu, wiring harness, axles (drivers side might need replacement), b16 tranny, and shifter links. I'm asking 700 or best offer. I'm located in Fort Pierce if anyone is interested.
