b18 turbo swap advice please
Hey guys! i've checked around the site a bit and there seems to be a lot of knowledgeable people, and i was hoping you might be able to give me some advice/tips/help with my swap
i've got a 90 civic dx hatch with a d16z6 swap and a little mazda turbo pushing around 9psi with a chipped p28. i want to take out the stock single cam with a tiny turbo and throw in my fully built b18 w/ a .57 trim garrett turbo.. the engine & turbo setup are already fully put together i just need an ecu, axles, mounts, and some kind of fuel management (one of my friends just sold his car and is trying to sell me his Greddy E-manage Ultamite for only $200! so give me your take on that too please) i want you're guys' opinion on how i should go about doing this swap, what things i should add/change, what kind of numbers roughly might i be looking at once tuned, and just any opinions and comments in general about the setup. i'd appreciate any feedback you guys can give me.
Engine/Transmission
- 98' JDM integra Type-R Block
- Eagle connecting rods (H-Beam)
- JE 9:1 pistons with JE rings, block bored .020" over
- ARP main studs
- ARP head studs
_ ARP rod bolts
- Golden Eagle block guard
- RC 550cc injectors
- OEM water pump, oil pump, timing belt
- Cylinder head is all OEM, rebuilt with new valve seals
- Magnecore sparkplug wires & MSD Blaster SS external coil
- 98' USDM integra GSR transmission
- Clutchmasters stage 3 clutch
- OEM flywheel
- B-series shift linkage
Turbo system
- Garrett (genuine) T3/T4 turbo
- .63 a/r exhaust
- 57 trim compressor
- oil cooled
- All Aeroquip fittings (oil feed (-4) and return (-12) )
- All stainless fastenters
- Exhaust manifold bolts converted to studs
- Log style turbo manifold
- port matched
- TIG-welded mild steel
- symmetrical wastegate exit
- wastegate dumps to atmosphere (not piped to exhaust)
- In-car adjustable boost pressure
- Mandrel bent charge piping, 2.25"
- Tube & fin intercooler 9" x 20" x 3"
- 2.5" outlet with re-welded 2.25" inlet
- inlet relocated for charge pipe volume reduction
- "back door" setup
- 300zx BOV with recirculation
- 3" mandrel belt intake
- Genuine K&N air filter
- 3" into 2.5" DP, stud-type connection to turbine
-DP has 3" dump with block off plate
also, because of the d16z6 swap, will the swap pretty much be the same as an eg swap? (eg. swap rear tranny mount & drivers side mount/wiring harnesses plug & play??) or will there need to be some sort of fabrication?
thanks guys!
Engine/Transmission
- ARP main studs
- ARP head studs
_ ARP rod bolts
- OEM flywheel
Turbo system
- .63 a/r exhaust
- oil cooled
- port matched
- "back door" setup
thanks guys!
um, you'd do it like any other b series swap...not really sure what you want to know
2 good threads for you to look through
https://honda-tech.com/forums/forced-induction-16/lst-ls-t-turbo-b18a-b18b-setups-1323059/
https://honda-tech.com/forums/forced-induction-16/%2A%2Aofficial-boosted-ef-thread%2A%2A-1771468/
BUMP;; cmon guys really just ANY opinions / advice AT ALL would be helpful.. plus noone even answered the two real questions i had!! ( should i buy the Greddy emanage ultimate for $200, and will the swap be EXACTLY the same as an EG swap because there's already a d16z6 in there??) because i know normally B18 into EF swaps are a bit more complex. i have the materials but i still don't know EVERYTHING!! thats why im saying ANY advice/opinions would be VERY VERY appreciated. thanks H-T.
no, it's not the same as an EG swap...heres some swap info
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
as far as the GReddy, check the forced induction forum. i gave you 2 good links to SEARCH in and/or ask questions in since they both wil probably have answers to your question.
TEAM HATCH-N-IT 90
Feb 1, 2005 05:45 PM
