All Motor Randy Garage Clean Out! OEM and Race!!!
Just a few things laying around that I'd like to get rid of. Thread will be updated weekly. ALL parts sold AS-IS!!! PM or Email me @ uniquerandyr@yahoo.com for any questions. Located in So Cal. Thanks for looking! Please bump it!
RACE Parts!!!
H22A race block, Golden Eagle HD sleeves (90.5mm), Custom Arias Pistons (.0045" P2W), Saenz Steel Rods, Cryo treated H23 crank (95mm), ACL Main (.0020"), Rod (.0020") and Thrust bearings, fully balanced, H2B ready.
$2500
GSR/B18C1 Darton Open Deck Sleeved Block, matching main caps, used for 84.5mm, may need to be honed to 85mm.......$850
Avid CRX B-Series Mount Kit, Brand New, never used!..... $250
Avid EK B-Series Mount Kit, Used..... $200
Cometic LS/VTEC 81.5mm .030" MLS, K20/K24 87mm .060" MLS head gaskets, Brand New! ...... $75/Each
Turbosmart Ultragate 38mm Wastegate, Brand New!..... SOLD!!
DC Sports Dual Bend Short Shifter, Opened but never installed....... SOLD!!!
Skunk2 Single Bend Short Shifter, needs new ball bearings...... SOLD!!!
CP Pistons, B-Series 84mm, 9:1 Compression, New with rings, wrist pins and locks....SOLD!!!
Eagle GSR Rods, New in box....SOLD!!!
Edelbrock B16 Intake Manifold for dual fuel rails, includes secondary fuel rail, barely used......... SOLD!!!
RC Peak and Hold Injectors PRC-1000, 1000cc...... SOLD!!!
OEM Parts
JDM EG Sedan Cluster....... $150
Civic CX (EG) Cluster....... $40
PR4 (LS) Oil Pump, Brand New!..... $100
B-Series Flywheel (P30), can use a resurface....... $20
GSR/LS B-Series Header.......... $60
PM6 (EF D-Series) OBD-0 ECU....... $20
CTR Strut Bar....... $60
GSR Manifold......... $50
B16 crank, uncut, no spun bearings...... $100
B16 (PR3 x 2)..... SOLD!!!
GSR crank, uncut, no spun bearings..... SOLD!!!
OEM JDM GSR LSD (unknown condition)....... SOLD!!!
B16A2 (99 Civic SI/EM1) short block, was running when pulled from car............. SOLD!!!
D15B2 (EF) Short Block, unknown condition....... SOLD!!!
L3 Cable D-Series Tranmission, unknown condition........ SOLD!!!
L3 Cable D-Series Transmission #2, unknown condition....... SOLD!!!
LS crank, uncut, no spun bearings...... SOLD!!!
GSR P72 Timing cover set (bottom, top and back pieces) X 2......... SOLD!!!
RACE Parts!!!
$2500
OEM Parts
Not too sure about the lsd.... I pulled it out of a transmission that I bought a while back and never installed it into another transmission.
