engine stalls
Old Sep 19, 2010 | 08:40 PM
litoekneeil's Avatar
Default engine stalls
Hey everyone.
Recently I rebuilt my JDM GSR. The motor consist of US ITR pistons .40 over, stock crank, stock rods, stock sleeves, OEM head gasket stamped 83mm, fresh GSR head with stock valve train (valve job and resurfaced), CTR cams, and blox intake manifold. I am running a virgin JDM ITR obd2a ecu. When I first turn the engine on, it idles great and everything. My problem is after I come to a full stop, my idle would dip and sometimes stall. Is that common for fresh rebuilt engines during break-in? I've searched around but haven't has any luck finding the answer. Any input would be greatly appreciated.
Old Sep 20, 2010 | 01:30 PM
Default Re: engine stalls
no one has any input?
Old Sep 20, 2010 | 05:15 PM
Aesthetic Gains's Avatar
Dos Pupusas
Did you try to adjust your mechanical idle screw? If not, try doing that and see if the car idles better when warm. Are you planing on tuning the set-up at all?
Old Sep 21, 2010 | 01:47 PM
Sighh.... I feel like a noob. I just finish adjusting my valves to spec. My idle problem went away.
rcurry14
Apr 6, 2017 06:05 AM
jameson_g
Dec 13, 2012 08:11 PM
litoekneeil
Feb 26, 2011 07:55 PM
akasen8
Aug 29, 2004 10:56 PM
