Vaccum Leak???
Old Sep 19, 2010 | 08:33 PM
Spoon84's Avatar
Default Vaccum Leak???
WHOOPS WRONG FORUM!!!! MOVE PLEASE!!!
I just built my GSR for boost. Its a fully built motor just installed it 2 weeks ago. I'm using a GM 3 bar map sensor and 880cc injectors. I have skunk2 pro manifold with 70mm TB portmatched. Motor starts right up, then starts to surge from about 1k to 1,500k rpm. I've checked for vaccum leaks, cleaned the IACV.
Also When you hit the gas fast like if your going to rev it to 3k rpm... it boggs for an instant before revving.
Could the surging be caused by a Basemap not being tuned?
I have not set the Timing either.
If anyone has had experience with this problem please shed some light. Thanks.
Old Sep 19, 2010 | 08:35 PM
kaiba's Avatar
Default Re: Vaccum Leak???
Posted in the wrong forum.
Throttle body gasket? MAP and TPS sensor switch around?
Old Sep 19, 2010 | 11:00 PM
slowman's Avatar
I took way too long
Explain more. I'm experiencing the same thing. Can having these plugged in incorrectly cause this?
Old Sep 19, 2010 | 11:07 PM
Spoon84's Avatar
Yes they could be possibly switched since the plugs are the same.. I know mine aren't switched because I looked up the colors on the harness and wired them to corresponding 3bar map sensor wires.
I have no CEL's or anything.
But having them switched would definently give you idling problems.
Old Sep 22, 2010 | 12:16 PM
slowman's Avatar
I took way too long
Wouldn't this cause a CEL having them improperly plugged in?
Old Sep 22, 2010 | 12:37 PM
fv8s's Avatar
clock your tps using a digital volt ohmmeter
Old Sep 22, 2010 | 04:52 PM
Spoon84's Avatar
did it already
Spoon84
Sep 30, 2010 01:06 PM
Spoon84
Sep 10, 2010 10:29 AM
m723tec
Engine Management and Tuning
Jul 11, 2010 09:00 PM
Hardedge
Dec 5, 2007 05:40 PM
HybridKOOP
Jun 25, 2003 11:10 AM
