axle help - what part of the half shaft am I missing?
hey guys im haven an axel problem here .. i made a mistake in throwing the old axel away so now im stuck ..
( engine and tranny are LS b18b1 )
heres pictures of my half shaft ...... im hearing that im missing something for my half shaft to go into the axel .. but yet the first axel that came with the car was the oppisite and had the end with splines that went into the half shaft
so i was wondering if anyone culd help me with telln me what im missing or what kinda axel to get cus the LS one they are given me is made for the halfshaft with a splined end
have you ever replaced them before? the halfshaft looks like its from a da, unless you somehow managed to break the spline'd end of the halfshaft, which you would need to be the hulk on steroids to do.
this is the last axel they gave me i havent tryd it yet cus thats when my menchanic called me tellin me i had the wrng half shaft , so i didnt try but can someone tell me if this is the one i need .. if not ill go pick up the other tomorrow
yah it takes like 10 minutes. pull the wheel, 4 19mm lugs. then pull the axle nut. 32nn.
take off the lower balljoint castle nut 17mm, then take off the strut fork bottom bolt 14mm.
then wack the side of the lower control arm till the balljoint pops out.
slip the old axle out of the hub, then from the halfshaft "screwdriver or crowbar is you friend here"
then slip the new one on.
put it into the half shaft, wiggle it til it goes in all he way, then put into the wheel hub.
bolt on the strut fork, and the lower ball joint. install NEW cotter pin.
install axle nut, make sure to hammer in the locking tab, and reinstall the wheel.
then go dump the clutch and do a sick burnout.
seriously, i replaced both my axles and axle seals in under 30 minutes, with basic hand tools.
bunkrd you
10
Sep 20, 2011 11:45 AM
13g-crx
Feb 16, 2007 11:32 PM
Cheeech
20
Dec 22, 2005 05:55 PM
