96 Integra stock radio won't hold security code after key off
Hey I'm having a weird problem that I can't figure out and search couldn't help me so I decided to make a thread. I'm putting my 96 GSR back to stock which includes taking the aftermarket headunit out and putting the stock radio in. I have the code for the radio and the radio works fine once its put in but I key off the ignition and once I key it back on, its asking for the code again.
I'm not running the 6 disk changer in the back but should that matter? All the fuses and wires look good so I'm stumped. Any ideas?
I'll check that out, it probably isn't getting power with the key off. Thanks.
As far as I know they are. I used a radio harness as to not damage the stock wiring when I put the aftermarket deck in, so I'm pretty sure everything is still intact. I'll have to double check everything since there is obviously a problem.
