WTH: someone to install my ASR brace, Itr sway, and blox rear camber kit asap!
Old Sep 18, 2010 | 09:48 PM
Mashi2Choco's Avatar
Default WTH: someone to install my ASR brace, Itr sway, and blox rear camber kit asap!
Hey ht! So I dot have the right tools at all to do this..my jack doesn't raise the car high enough so the jack stands can't even fit under the car... And I don't have the air tool nor a impact wench...
The holes on the subframe are already drilled out so it's all just basically bolting em on! I need someone with the right tools and can
do a proper job installing all of that asap!
Because I seriously need an alignment since my wheels rubsy fender when I turn...
Thanks!!!
Old Sep 18, 2010 | 10:33 PM
94GSRlbc's Avatar
Default Re: WTH: someone to install my ASR brace, Itr sway, and blox rear camber kit asap!
pm me
Old Sep 18, 2010 | 10:41 PM
Originally Posted by 94GSRlbc
pm me
PMED!
Old Sep 18, 2010 | 10:46 PM
k20_typeR_EG's Avatar
if ur local to SFV i can help u out hit me up 18184288112
Old Sep 18, 2010 | 10:47 PM
eg2jr's Avatar
easy yob. and you don't need an impact gun or air compressor
Old Sep 18, 2010 | 10:48 PM
94GSRlbc's Avatar
ill think about it not a bad price all you need is a rachet with a 14mm 13mm and a 12mm your good to go
Old Sep 18, 2010 | 11:04 PM
I think that's too far away, an hour drive....
The thing is my jack can't raise the car high enough for my jack stands, so the car is unstable....
I need to get it done Sunday morning ASAP and then an alignment right after so let me know
Old Sep 19, 2010 | 12:07 AM
sunday morning to afternoon ish anybody?
Old Sep 19, 2010 | 12:15 AM
cancel's Avatar
jack the front up first then jack up the rear itll fit jackstands under.. as long as your jack can lift 15" ++ itll work, i used to do it all the time if you jack up the rear only you need a jack lift of 20"++ to fit jackstands dont gotta pay anyone if you take your time with it should be 2 hours at most, or 1ish like me if you got experience
gL
Old Sep 19, 2010 | 12:39 AM
JDMKAY's Avatar
ttt u!!!!
Old Sep 19, 2010 | 01:15 AM
I only have one jack tho, how does that work exactly?...
Old Sep 19, 2010 | 02:05 AM
last bump! hope someone would able to help me out tomorrow morning!
Old Sep 19, 2010 | 03:54 AM
geneeunit's Avatar
im in corona, ca. or can be in garden grove / west covina area.
shoot me a text if you need some help. 626 251 3584
Old Sep 19, 2010 | 09:40 AM
bump!
Old Sep 19, 2010 | 10:15 AM
Sean @ ESG's Avatar
pm me
fatfurious2
Feb 21, 2008 04:01 PM
Jonathan_ED3
Mar 29, 2002 12:41 PM
