Help me locate the reverse light switch on the tranny!
Old Sep 18, 2010 | 08:51 PM
spoolinq's Avatar
Icon2 thx!
thx!
Old Sep 18, 2010 | 08:55 PM
bluevic99's Avatar
Default Re: Help me locate the reverse light switch on the tranny!
look on the front lower part of the trans and there is were it will be. Its almost on the bottom of the trans but up front. Hope this helps
Old Sep 18, 2010 | 08:59 PM
teggi's Avatar
the one on the last pic is what you are looking for
Old Sep 18, 2010 | 09:00 PM
Former User's Avatar
The top picture shows the VSS.
The loose plug is likely for the back up lights switch, which should be located just rearward of your hand in the picture where you are holding the plug. Look in the area of the transmission below the distributor.
Old Sep 18, 2010 | 09:03 PM
spoolinq's Avatar
thx!
Old Sep 18, 2010 | 09:07 PM
No, that's a vent tube. The switch is located just rear of that tube below the distributor. It's visible from above because it sits on top of the transmission.
Old Sep 18, 2010 | 09:08 PM
EJeff8's Avatar
If you look straight down at your tranny, it should sit at the front of it on top.
The VSS is toward the back, the Backup switch is toward the front of it
Old Sep 18, 2010 | 09:09 PM
bluevic99's Avatar
You know I have had my trans out like 4 times and my sensor isnt located there. Is yours a five speed or a automatic.
Old Sep 18, 2010 | 09:22 PM
bluevic99's Avatar
Here you go
Old Sep 18, 2010 | 09:25 PM
spoolinq's Avatar
thx!
Old Sep 18, 2010 | 09:28 PM
bluevic99's Avatar
well the harness peice that your holding in the pic looks to be going to the sensor right below the slave cylinder you should be able to find it. Its black and it will have wires coming out of it.
Old Sep 18, 2010 | 09:52 PM
Originally Posted by spoolinq
This is a 5spd. I still cant find it I figure if the clip is dangling from the engine harness then the sensor on the tranny should be dangling as well (or it could be missing). I'll try jacking up the car tomorrow and try from underneath.
The switch is visible when you are standing in front of the radiator. It's on the top of the transmission not the bottom. Take clear pictures of the top of the transmission just below the distributor. The switch should be sticking up from the top of the transmission not dangling from the connector.
Old Sep 18, 2010 | 10:11 PM
D16SiHatch's Avatar
searched OP's other threads and confirmed my suspicions that he has a b-series engine (b18c1 specifically), so the switch is on the bottom of the transmission.
Old Sep 19, 2010 | 02:55 AM
94EG8's Avatar
Seagull Management
The plug thats not going anywhere is coming from the backup light switch itself, simply follow it back.
Old Sep 19, 2010 | 05:58 AM
Nice job with the detective work.
Old Sep 19, 2010 | 05:23 PM
spoolinq's Avatar
thx!
Old Sep 21, 2010 | 06:31 PM
bluevic99's Avatar
Something is shorted and you need to make sure you got the wires correct and that you don't have any bear wires touching
Raven2201
Jul 3, 2013 05:36 AM
meallout
Oct 31, 2008 04:36 AM
aziaticvang
Jan 17, 2008 08:56 AM
hatchling37
Jun 25, 2004 08:27 AM
gleinz
Jul 13, 2002 09:44 PM
