Car pops out of 5th gear
Originally Posted by hatchet_honda
ynchros!! does it come out of gear once you release the gas pedal?
The fluid he was refering to was gear oil. I had a trans that leaked itself dry on a long drive once and it started popping out of 5th if I wasn't holding the shifter. Put oil in the trans and it was fine after that. Could also be a bad synchro.
Ive seen low fluid levels cause this exact same thing. Check the fluid level first.
the clutch fluid has been depleting slowly, but there is plenty in there.
well just be glad that trannys' for the ex only cost about $150 at the junkyard.
if you wanna be cheap you can get a DX trannyy for about $70 at the junkyard, and just suffer a little acceleration loss, and the gain of better fuel mileage. and you can take it out, put a clutch in, and put the new tranny in, in under 4 hours
I had this EXACT SAME PROBLEM in my hatch and it was low tranny fluid, change your fluid i can almost guarentee thats the problem. Post back and let us know what happens.
-Josh
-Josh
