Are an Oil pressure switch and oil pressure sender the same thing?
Old Sep 18, 2010 | 07:17 AM
letsclique's Avatar
Icon6 Are an Oil pressure switch and oil pressure sender the same thing?
I wanted to know if an oil pressure switch and a oil pressure sender are the same thing? I don't want to buy the wrong part. This is for a 1990 Honda Accord DX. Thanks.
Someone said that I could just use Teflon tape instead of a sealant when I replace it. Do you think that will work and where do you buy Teflon tape at?
Old Sep 18, 2010 | 07:23 AM
poorman212's Avatar
Default Re: Are an Oil pressure switch and oil pressure sender the same thing?
Yes they are the same. At the same place you get the switch from should also have the tape.
leflore
Apr 26, 2013 04:40 PM
Gsir8
Jun 29, 2007 04:46 AM
doublejz
Jan 1, 2004 09:46 PM
