Stock GSR compression ratio + p73 pistons
(00 GSR B18C1 USDM) Hey guy Im trying to find out what a GSR stock compression ratio is, I Search and found 2 different answers. 1 is that ratio is 10.0:1 and some other people say ratio is 10.6:1. So what if I swap out to USDM type-r pistons, What will my compression ratio be on a stock gsr w/ P73 pistons? I found a few different answers so I'm not sure who is right...
you better put some cams in there to and tune. i made the same mistake after i blew my motor. put usdm ITRs in and it made my car SLOWER even after a tune. i was pissed. so i built my head then it helped! but it bumps it to 11:2:1 i believe. its been several years
and btw i have a full bottom end rebuild kit if you need it, if you run standard bore everything
acl bearings,new rings,gaskets, etc all new
So I did some more digging and found out, That b18c1 is 10.00:1 and If I was to instal P73 pistons I would get 11.04:1, Guys dose this sound right to every one? I used http://www.zealautowerks.com/bseries.html
Tune is your friend btw
tsjag17
Aug 31, 2001 09:51 AM
