Hub bearing on 97 tegger help me please????
Old Sep 18, 2002 | 06:31 PM
DeDonDeRosa's Avatar
Default Hub bearing on 97 tegger help me please????
has anyone ever done hub bearing on a teg and if so was it hard and one more thing how can you tell if you need hub bearings???
cause if im crusing and everytime i turn the wheel right all you hear is a wuwuwuwuwuwuuwuwuwuwuuuuuu noise im pretty sure it needs it but just help me out thanks
Old Sep 18, 2002 | 10:15 PM
rotten's Avatar
Default Re: Hub bearing on 97 tegger help me please???? (DeDonDeRosa)
Stop the car, grab the top of the wheel/tire and yank it back and forth fairly hard. If it moves much at all then you'll need a new wheel bearing.
To replace the wheel bearing, take of the wheel, caliper, disc, basically everything off the knuckle, then remove the knuckle and get the old bearing pressed out and the new one pressed in.
Would be a good time to put in extended lug nuts if you're planning on doing that, hit two birds with one stone.
Bearign should cost you about $30-$45, to have it pressed probably another $20 or so.
Old Sep 19, 2002 | 06:52 AM
Default Re: Hub bearing on 97 tegger help me please???? (rotten)
my wheel doesent move when i pull on it back and forth but when im driving and i turn the slightest to the right it makes like road noise wuwuwuwuuw i think im just gonna do it anyway cause the car has 90 k on it and i think it would be a good time to do it
EJ8mike
Mar 13, 2013 06:28 PM
antig24
10
Apr 22, 2008 09:31 AM
CivicVX94
Oct 15, 2007 05:42 PM
nickpapa
Aug 27, 2007 03:43 AM
pcorad
Nov 7, 2001 08:41 AM
