Z6 failed compression test: Do I need new block or new head gasket?
So after failing a compression test, I opened up the head on my D16Z6 and discovered some chips on the sleeves. It doesn't seem like it would propagate to the cylinder walls. What am I looking to replace?
As I posted before its done. Pick up a JDM SOHC Vtec ZC, new OEM waterpump, timing belt, thermostat and PCV valve and that will run another 200,000.
Could it be possible that those chunks got into my water pump. My car overheated bad right before this happened
Thanks everybody, and yeah phaphon, I think I'm gonna slap a new gasket and ride it out. see how long it lasts. How long did yours last?
B-series engines are pretty robust when it comes to headgaskets, D-series, not so much. Its your call, but 5 out of 6 people just told your block is junk. By the time you add up new headgasket, headbolts, intake manifold gasket, water pump and most likely thermostat its not that cheap to throw a headgasket in. Besides like i said the last time you posted this it looks like its ready to be re-ringed, it may not have burned oil before but it will now.
I'm gonna check the water pump tonight and see how that's working. I guess I'll drain the water jacket too and see if I can find the pieces. Otherwise I don't know where the hell they would be.
It may last a while, it may not work at all, it may leave you on the side of the road somewhere and with an expensive tow bill. like I said its your call, just ask yourself if you can afford for it not work, if you can then sure go for it.
Undercover_Skank
Oct 16, 2011 04:55 PM
tundra2000
Apr 29, 2011 08:35 PM
straightshot08
Jan 26, 2010 04:20 PM
block, civic, commpression, comprepsion, compression, engine, failed, gasket, gaskets, head, honda, test, z6
