emanage ultimate basefile
Old Sep 17, 2010 | 02:22 PM
Spawne32's Avatar
Default emanage ultimate basefile
Does anyone have a copy of a emanage ultimate tune that i could use as a basefile for a b18 running on 5psi? Im trying to get this thing semi drivable but im having a bit of trouble with the learning curve here. Ive only been able to figure out thus far that you can + and - ignition timing and duty cycle based on map voltage, throttle position, and kpa/psi pressure readings. I have been unable to get the autotune feature to activate to make adjustments.
Old Sep 17, 2010 | 06:26 PM
Spawne32's Avatar
Default Re: emanage ultimate basefile
nobody?
anton_
Engine Management and Tuning
May 20, 2008 11:07 PM
thewrai6th
Jun 29, 2007 01:41 PM
W O T
Aug 13, 2006 03:27 PM
J337_UNIT
Feb 23, 2004 10:38 AM
scatuli
Sep 15, 2003 02:04 PM
