Transmission & Drivetrain Gearboxes, Differentials, Clutches
Axle popping out after gsr to b16 trans swap
Old Sep 17, 2010 | 01:45 PM
MindLess311's Avatar
Default Axle popping out after gsr to b16 trans swap
Alright guys well here is the situation i think i have it solved but want to know if im right. I swapped from a gsr to a b16 trans in my car. Ive been having a problem with the pass side axle popping out. Im running integra axles in my car its a 92 civic. Whats happening is that i cant seem to get the lock ring/ clip what ever you want to call it to lock in. Now after dealing with this i took a minute and looked at my gsr trans compared to my b16 and took the old measuring tape to it. Seem like the b16 trans needs a 2 1/4 shaft to the lock ring as opposed to the gsr only needed like 1 7/8th. So am i right here thinking that i need a different axle to work with this diff. Im thinking a del sol b16 axle possibly? Any help would be great thanks guys.
Old Sep 17, 2010 | 03:30 PM
Default Re: Axle popping out after gsr to b16 trans swap
guess im wrong everything seems to be coming up with the same part number i dont get whats going on here
Old Sep 22, 2010 | 02:26 PM
bryse68's Avatar
the differential is bad.......
xcheckmate88
Jul 27, 2013 08:08 PM
94b16coupe
Nov 14, 2010 10:40 PM
Slow_import
May 15, 2009 08:47 PM
