idle rev's and drops repeatedly
Old Sep 17, 2010 | 10:07 AM
RushGiver29's Avatar
From: West Des Moines, Iowa, United States of America
Default idle rev's and drops repeatedly
Hey I just put a 98 base engine into my 99 shell, atm she starts and drives but my idle is going up to about 2000rpm and droving and doing it over and over. I suppected coolant is trying to be sucked in and possibly I have air bubbles. I rechecked all hoes vaccum lines and everything else but can't seem to find any unhooked hoses or plugs. I was also told that I may need to bleed it, and or flush, and change out the termostat. I'm gonna do the thermostat later tonight but wonder if any opinons or answers to where else to start or how to fix the problem will be appreciated thanks
Old Sep 17, 2010 | 10:24 AM
minilogoguy18's Avatar
Default Re: idle rev's and drops repeatedly
If it does it when its cold then adjust the FITV, if it does it all the time replace the IACV. While there is a CEL for the IACV it only comes on if the engine doesn't detect one, wont throw the code if it's going bad.
Old Sep 17, 2010 | 02:04 PM
snobordboy's Avatar
Moderator
This should give you all the help you need.
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
Old Sep 17, 2010 | 07:40 PM
sde780's Avatar
mine did it when the line going from the valve cover to the intake wasn't there. I replaced it and it's fixed. Clean your IACV as well
Old Sep 17, 2010 | 07:49 PM
H23_del_soul's Avatar
I would start by cleaning the IACV, it's free and quick.
bgroves1504
Mar 15, 2017 05:43 PM
joshua89
Aug 20, 2011 01:47 PM
Harddrnker
13
Jan 25, 2009 01:12 PM
akteamster
23
Jan 31, 2005 08:18 AM
[ iLL ] iNt3GrA
Jun 16, 2004 05:44 PM
