Suspension & Brakes Theory, alignment, spring rates....
89 Accord - Front Sway Bar Mount
Old Sep 17, 2010 | 07:55 AM
mnmsddy's Avatar
Default 89 Accord - Front Sway Bar Mount
Need Help... The front sway bar mount on my 89 Accord has ripped the mounting screw out of the sub frame. I have a full on Jackson Racing kit, it was called the Mulholland back in the days ( 1990) when I installed it, the kit was front and rear sways, tokico shocks and new springs, a mild drop that hangs corners very well.. I am thinking I need to make a sleeve that I can bolt onto the subframe with new mounting holes for the sway bar mounts... has any one seen this or had to fix somthing like this.. It has happened about 6 years ago, and at that point we tapped it bigger and put a new bolt through it... No way to do that this time.
Any thoughts or ideas would be great
Old Sep 17, 2010 | 09:53 AM
Importordomestic's Avatar
Default Re: 89 Accord - Front Sway Bar Mount
you need to take a look at www.3geez.com. As a fellow 3g owner here is my recommendation. the rear subframe is removable from the vehicle. just pull the engine out, remove subframe and replace it with one from the junkyard.
Old Sep 17, 2010 | 10:15 AM
mnmsddy's Avatar
I headed to 3geez first... I have not been able to get to that site for the last few days... may be the proxies here at work.
Thanks for the recomendation
lukegail
Suspension & Brakes
Dec 23, 2009 09:48 PM
f22builder
Jun 12, 2009 12:52 PM
GroundZer0 336
Sep 19, 2006 02:24 PM
bradykiller
13
Sep 14, 2004 02:10 PM
