QSD H2B kit, TODA,ACT, H2B swap components,ESP, ETC>
FIrst up.
H2B kit SOLD!!!!!!
ACT Heavy duty pressure plate and clutch disc for b-series
-About 5k miles on the plate/disc
-YOUR CHOICE of cable b-series unsprung 6 puck disc(J1/Y1/A1/S1), Or 6 puck sprung disc(Hydro b series, and cable YS1)
-Held fine in the H2B setup.
$150
ESP H2B Header with 2.5" straight pipe
-4-2-1 design
-2.5" outlet
-Light dents on the bottom, not major
$200
Skunk2 70mm throttle body and H22 port matched upper plenum.
-S2 70mm TB with
-rosko racing thermal gasket
-H22A upper plenum ported out to 70mm to match the TB
-Comes with MAP and TPS sensors
$200
Boomslang jumper harness
-obd0-obd1
-kill switch included in line with dizzy ignition coil signal
$75
I can make it plug and play for $150
AEM F/H series fuel rail with earls inline filter
-fit any f/h series engine.
$100
[b][color=red]All prices are WITHOUT shipping! Located in North minneapolis MINNESOTA but wiling to ship to anywhere!!!!!!!
Things sold:
-TODA flywheel
-H2B kit
-shaved crank pulley
-KS BS eliminator kit
-Chipped ecu
-TYPE-S VC
-alt. relocation kit
-axles,mounts,shift linkage
<br /><br />
Modified by theVTECnician at 7:25 AM 10/24/2010<br /><br />
Modified by theVTECnician at 4:35 PM 11/15/2010
H2B kit SOLD!!!!!!
$150
-4-2-1 design
-2.5" outlet
$200
-S2 70mm TB with
$200
-obd0-obd1
$75
$100
Things sold:
-TODA flywheel
-H2B kit
-Chipped ecu
-TYPE-S VC
<br /><br />
Depends what it is I guess. Pm me. I need cash though
Yeah it's technically sold. Had to sell it for $$$ to start my business man. Sold it to a good buddy though and not some random dude.
It comes with everything you would get from QSD.
-Adapter plate
-flywheel spacer
-Cam gear side engine mount bracket that bolts to the block
-Half shaft bracket
-All ARP hardware/washers supplied by QSD
The price i listed ($675 obo) only includes the things listed above, BUT I do have a full EF mount set for sale including axles, shift linkage, and trans bracket I could throw in for a package deal with a little discount for purchasing it together.
-Adapter plate
-flywheel spacer
-Half shaft bracket
BUMP
Wish you had this kid for sale before i bought a new one.
Low on cash and unemployed right now but I still need some of this stuff so if you still have it in a couple weeks ill hit you up.
I don't sell kids, sorry!
JK
SHould have some stuff left over. This stuff is moving, but not as fast as I'd thought initially.
JK
I'll do $350 for the clutch kit and pressure plate. They were over $700 new. That's the best I can do!
Thanks!
Derek
Thanks!
Derek
