2000 Civic - Noise caused by crack in Exhaust Manifold?
Old Sep 17, 2010 | 12:51 AM
zackn8's Avatar
Default 2000 Civic - Noise caused by crack in Exhaust Manifold?
I recently began to hear a mechanical noise only when accelerating. The mechanic listened and said it was probably my exhaust manifold and that I could replace it any time I wanted.
I've taken a picture and included it here. Would a crack like this cause any noise upon acceleration? Also, is it truely something that is not an immediate concern?
Old Sep 17, 2010 | 01:32 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Exhaust Manifold 2000 Civic
yeah it'll cause noise and can throw off your oxygen sensor reading causing some irregular gas mileage.
Old Sep 20, 2010 | 04:53 PM
zackn8's Avatar
I just took the mileage yesterday - 189.7mi/4.559gallons = 41.6 mi/g approx. (all freeway)
Since it only makes this noise upon acceleration - wouldn't this rule out the exhaust manifold? I'd assume that if it was the manifold crack, it'd be a constand noise. It sounds like ball bearings rattling around (like a mini semi-truck) when I hit the gas.
Old Sep 21, 2010 | 02:21 PM
Spacefey's Avatar
Default Re: 2000 Civic - Noise caused by crack in Exhaust Manifold?
Think you would loose performance due to the hot air warming up your motor compartment. But with the heat-shield it shouldn't be noticable with your butt-meter
Old Sep 21, 2010 | 02:36 PM
Deetz's Avatar
Crazy Honda Guy
That is a very common problem with that particular manifold design. If you are willing, go to your local pick n pull and find a decent used one, which should be pretty cheap.
New at the dealer, it's a pricey part
AudioFunk
Apr 8, 2014 07:47 PM
dakota1820
Honda Civic (2001 - 2005)
17
Apr 16, 2013 07:01 PM
blackie
Jul 19, 2005 12:07 PM
RedGSRBull
May 23, 2003 03:31 AM
