h20 Power: q's about water injection and water cooling?
Old Sep 18, 2002 | 06:03 PM
comptechgsr's Avatar
Default h20 Power: q's about water injection and water cooling?
pros and cons?
which cars have em?
etc etc?
i jus wanna learn about this
Old Sep 19, 2002 | 04:43 AM
Bontke's Avatar
Default Re: h20 Power: q's about water injection and water cooling? (comptechgsr)
Well ater injection is pretty neat. i have seen it mostly on turbo cars that get a hot intake charge. It cools the air in the engincylinder and when it is compressed the 02 is burned resulting in more power. Downside is if you don't tune for the extra oxygen in the cylinder you will run lean possibly damaging your engine. I haven't heard many bad things.
Old Sep 19, 2002 | 03:09 PM
Default Re: h20 Power: q's about water injection and water cooling? (Bontke)
thanks for the info man
Old Sep 20, 2002 | 05:57 AM
kinesistech's Avatar
It doesnt add oxygen. It resists detonation. You can get more reliability with water injection. You run a 50/50 mix with alcohol. The water uses btu's of combustion chamber heat to convert to steam. Change of state cooling like that is very efficient. The alcohol will have added octane. Water injection can enable more boost or more advanced timing. Its great insurance if nothing more.
Old Sep 20, 2002 | 08:43 AM
Bontke's Avatar
Default Re: h20 Power: q's about water injection and water cooling? (kinesistech)
Water injection does break down oxygen atoms. It will run the engine leaner. Not so much like nitrous, but it does release oxygen. Anyhow, depending on the application you will need to add some fuel. It also breaks up carbon deposits in the cylinder.
Old Sep 20, 2002 | 11:26 AM
cool cool
what are "btu's"
Old Sep 20, 2002 | 11:51 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
BTU- British Thermal Unit
units of heat
stan
jep
May 24, 2006 11:47 PM
mdixonjam
Apr 25, 2005 04:25 AM
boosted hybrid
Dec 3, 2002 10:35 AM
IMJUSTBORED
Oct 3, 2002 09:41 AM
Turbo00
Sep 13, 2001 11:06 PM
