AC ISSUES IN RHD CONVERTED CIVIC BLOWS FULL ONLY
Old Sep 16, 2010 | 07:40 PM
TUR3Ovtec's Avatar
Default AC ISSUES IN RHD CONVERTED CIVIC BLOWS FULL ONLY
Hey, ok so a RHD converted civic with a EK9 climate control (big 3 dials like 99-00 civic's) air only work on FULL BLAST... IF you turn the ac system on a lower speed it turns off. What gives? Any insight would be nice because im tired of turning the system on and off...
Old Sep 16, 2010 | 08:00 PM
Former User's Avatar
Default Re: AC ISSUES IN RHD CONVERTED CIVIC BLOWS FULL ONLY
That's often caused by a bad power transistor.
Old Sep 16, 2010 | 08:03 PM
TUR3Ovtec's Avatar
gotcha... thanks dude... if i wanted to take that out would it be difficult to do it? I mean do i have to take out the whole heater box and everything to get to it or?
Old Sep 16, 2010 | 08:13 PM
You can access it after removing the glove box.
Old Sep 16, 2010 | 08:19 PM
TUR3Ovtec's Avatar
thanks dude ur the best!!!!
Old Sep 16, 2010 | 09:15 PM
TUR3Ovtec's Avatar
now i got a problem... popped open the glove box and i come to see this hell of a mess... wires exposed...
two are coming from the power transistor
Old Sep 16, 2010 | 09:16 PM
TUR3Ovtec's Avatar
is there a difference between a rhd coverted box and the usdm box?
Old Sep 16, 2010 | 09:29 PM
lunareg's Avatar
holy ****, thats a fire hazard if ive ever seen one.. dont you just love finding things like that? get some butt connectors and fix thats jank fast.. at least wrap some etape on it.
and I mean hell, if I had a rhd I wouldnt care about ac
Old Sep 16, 2010 | 09:32 PM
TUR3Ovtec's Avatar
yeah i already did that... first thing that crossed my mind was the fire dept LOL... any help on what those should be connected too???
Old Sep 16, 2010 | 09:48 PM
Old Sep 16, 2010 | 09:52 PM
lunareg's Avatar
ive lit up alot of wires back in the day doing stereo stuff and most of the time the casing just burns off and no harm done, but its nothing to leave to chance and yeah thats a hot mess half the wires arent connected.. I hate electical stuff, and that chart ron posted looks like its written in alien to me ><
Old Sep 16, 2010 | 09:55 PM
It looks more complicated than it is. The red dot marks the power transistor. You can then follow the wires (lines) indicated by their colors to know where the transistor wires run to.
TUR3Ovtec's Avatar
yeah me too... i have no idea where that should be connected too LOL... i saw the same thing on the haynes manual and i was like wtf... ****
Old Sep 16, 2010 | 09:56 PM
TUR3Ovtec's Avatar
Hey ron how come that illustration doesnt show the red wire???
Old Sep 16, 2010 | 09:58 PM
lunareg's Avatar
ahh yeah i see, well assuming those wires are the correct colors it shouldnt be -that- bad.
Old Sep 16, 2010 | 09:59 PM
TUR3Ovtec's Avatar
so there is only supposed to be three wires... why the hell do i have 4????
Old Sep 16, 2010 | 10:01 PM
The power transistor should have a 3P connector with 3 wires. Is your connector 4P with an additional red wire?
TUR3Ovtec's Avatar
thats what it looks like i got a green, red blue, and black wire coming out of it
Old Sep 16, 2010 | 10:06 PM
Hmmm...the 96-98 Blower resistor has a 4P connector, but the wires don't match:
Unplug your transistor connector and post clear pictures of both the wire and pin sides of the connector.
Old Sep 16, 2010 | 10:17 PM
Does the transistor connector look like this:
Old Sep 16, 2010 | 10:21 PM
TUR3Ovtec's Avatar
Old Sep 16, 2010 | 10:23 PM
TUR3Ovtec's Avatar
as you see in the picture the green wire is connected to a green/black from harness the black is connceted to a ground on harness and the blue and red wire are just there not connected to anything... then there are those two wires the yellow/black and green/yellow/black wire from the harness not connected to anything either
Old Sep 17, 2010 | 04:21 AM
TUR3Ovtec's Avatar
bump
Old Sep 17, 2010 | 01:44 PM
TUR3Ovtec's Avatar
alright update for u ron.... tried 2 new power resistors from a 99 civic ex and still doingt the same thing... used to wiring also to a 3p connector
Old Sep 17, 2010 | 02:11 PM
You have a 99-00 heater control panel and what appears to be a 96-98 heater/blower unit. If you compare the circuit diagrams, you'll see that the 99-00 system has a blower motor high relay (see post #10) whereas the 96-98 system does not (see below). Maybe this relay, along with the 99-00 3-wire power transistor, is what's missing in your system and what's needed to make it work.
