Problem with cam installation in Y8 head
Old Sep 16, 2010 | 06:30 PM
WanaBeFaster's Avatar
Default Problem with cam installation in Y8 head
I have been searching for days and can't find the answer to my question. I am installing a cam in a y8, but when I tighten the cam cover/rocker arm assembly, whatever you want to call it, the cam binds and will not rotate. I can get about 1/4 inch of a turn out of but will not go any further. Is it supposed to be that tight? Or should I be able to rotate it? Head is installed on the block, no timing belt.
This is my first time putting a sohc vtec together, so please forgive me if its a noob question, but I can't seem to find any answers. Thanks in advance for any help.
Old Sep 16, 2010 | 08:26 PM
Adamvanxxx's Avatar
Default Re: Problem with cam installation in Y8 head
Um, valve hitting a piston at TDC?
delsoldrew
15
May 31, 2020 11:29 PM
4potnick
Sep 3, 2006 11:57 AM
CivicManLs
Aug 8, 2006 08:50 PM
BIGTUNA
Mar 14, 2006 02:22 PM
