JDM D15b vtec head/D16y8 block: What timing belt do I use?
Old Sep 16, 2010 | 12:47 PM
redturboeg's Avatar
Default JDM D15b vtec head/D16y8 block: What timing belt do I use?
I've searched on google and many other sites and can't find an answer to my odd ball question. I have a JDM D15b vtec that I'm taking the head off of and putting it on a D16y8 block and I don't know what timing belt to use on it.
Should I use the one off the D15b or a D16Z6 timing belt? The block will have a D16z6 crank in it if that matters any.
Old Sep 16, 2010 | 01:43 PM
redturboeg's Avatar
Default Re: Timing Belt
Early bump, I would like to know before weekend so I can have my car running by next week.
Old Sep 16, 2010 | 02:57 PM
Former User's Avatar
Default Re: JDM D15b vtec head/D16y8 block: What timing belt do I use?
An good thread title is required and helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Old Sep 16, 2010 | 03:22 PM
94EG8's Avatar
Seagull Management
Y7/Y8 belt will work, 104 teeth, Z6 should work too but has a different part number for some reason, same number of teeth though.
Old Sep 16, 2010 | 05:35 PM
redturboeg's Avatar
Alright thanks guys, I was reading a little and I think the y7/y8 is different because the water pump is different so I have to find out if it has a y7/y8 or z6 water pump.
Mr learns alot
10
Dec 16, 2013 09:44 AM
hb_guy
Jan 26, 2006 06:04 PM
Calvinator
Sep 27, 2004 02:09 AM
lohatch
Jun 15, 2004 07:44 AM
davken1102
16
Jan 10, 2004 09:24 AM
