Odd RPM during idle.
Old Sep 16, 2010 | 11:44 AM
Sky1night's Avatar
Default Odd RPM during idle.
Hi, I have a 98 honda accord, V6, auto-transmission.
Just notice something odd about my car recently. After I park my car, the RPM is normal near 1000. But if I step on the pedal to rise the RPM, the RPM remain the same and don't drop back down. I gently bring the RPM to 2000 - 3000, it will go up and don't come back down. Only way it will go back down is if I put my car into Reserve, Neutral or Drive. All the fluid is fine, because I just change the motor oil and the coolant level is normal. No check engine light on and the only problem I have with the car is an old battery. Car drive fine as usually and fuel usage is the same.
Anyone ever experience the following problem before ? Feedback is appreciated, thank you.
Old Sep 16, 2010 | 11:50 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Odd RPM during idle.
Have you ever changed the transmission fluid......
Old Sep 16, 2010 | 12:02 PM
Sky1night's Avatar
Yes probably less than a year ago, less than 10,000 miles for sure.
Although it is a very old car, I only have 80,000 miles on it.
Old Sep 16, 2010 | 08:23 PM
Sky1night's Avatar
O, it only occur when the engine is hot.
unhappy_idle
Jan 24, 2006 01:29 PM
eaf
Sep 9, 2005 09:46 AM
jonah
Jul 5, 2005 07:06 AM
xben420
May 26, 2005 04:40 PM
