lower ball joint hitting rotor
Old Sep 15, 2010 | 07:43 PM
drtysoufchevy's Avatar
Default lower ball joint hitting rotor
I have a 96 civic hatch and i have skunk2 coilovers and camber kit. For some reason my lower ball joint hits my rotor when i turn. As you can see in the picture it has rubbed a hole in the shield. Has anyone ever had this problem and how do you fix it? and the hatch is not lowered that much.
Old Sep 15, 2010 | 09:26 PM
Hello Bart's Avatar
Default Re: lower ball joint hitting rotor
ive had the problem... when undoing the ball joint.. the shiel usually gets bent towards the rotor and is scraping... which usually happens on turns but can also rub when the wheel is straight.. try and just pry the sheild away from the rotor as much as possible.... works every time, just use a screwdriver or pry bar
Old Sep 15, 2010 | 09:27 PM
Hello Bart's Avatar
and your sheild definetly looks pretty banged up...
Old Sep 15, 2010 | 10:56 PM
its the lower arm control that is hitting the shield!
Old Sep 15, 2010 | 11:22 PM
virgineg6's Avatar
imma have to agree with bart jus pull it away from the control arm
Old Sep 16, 2010 | 02:07 AM
Nichelson_Performance's Avatar
hmmm that's looks weird, i never had that problem or saw that happen...kinda looks like it could possibly be a bad wheel bearing. it's possible to rub but should never wear a hole through it like that
Old Sep 16, 2010 | 02:09 AM
Eran's Avatar
HT White Ops
With your situation, just pull the shield away from the ball joint. There are other cases of this happening, but not with stock brake set-ups.
Old Sep 16, 2010 | 09:06 AM
The wheel bearing on the pass side is brand new and it still does it there, and its not the LBJ thats hitting the shield its the LAC.
Old Sep 16, 2010 | 09:08 AM
speedooo's Avatar
that shield is flimsy and very bendible...like everybody else just said, use a screwdriver and bend it away. Not that big of a deal.
Old Sep 16, 2010 | 09:45 AM
thats not my problem, my problem is my is my LCA hitting the rotor
Old Sep 16, 2010 | 10:13 AM
http://i49.photobucket.com/albums/f2...y/IMG_0462.jpg
this is with the car on the ground
Old Sep 16, 2010 | 10:20 AM
JDM_SOHC's Avatar
You guy's arent completely understanding wtf he's talking about... The LCA goes through the brake shield and grooves into the rotor, so it's penetrating deeper in than we can see...
Someone with an EK hatch can you go check ur LCA's and see if they curve up like that where the lower ball joint goes in... My EG's LCA goes straight it doesn't have that little curve up near the outer end..
Old Sep 16, 2010 | 10:34 AM
virgineg6's Avatar
damn definitely something else going on there thats not good at all, good luck with that
Old Sep 16, 2010 | 10:41 AM
JDM_SOHC's Avatar
Yeah that's what I'm saying... This is my cousins EK hatch "drtysoufchevy" so I'm trying to help him out a bit here but he lives across state or this issue would be fixed already hahaha... Naa but seriously, to me I think those are possibly the wrong LCA's or wrong Camber Kit making them touch at the bottom like that... When the front wheel is cambered in, it doesn't touch he said, but when the camber is set at 0 and the wheel is straight up/down it touches like we see in the pics... I can only imagine all the lovely noises that must make while doing 90 on I-75 lol...
Old Sep 16, 2010 | 11:00 AM
only on the on ramp to 75, haha
Old Sep 16, 2010 | 11:04 AM
Former User's Avatar
I moved a copy of this thread to the Suspension subforum to see whether you get more input there.
Old Sep 16, 2010 | 11:07 AM
JDM_SOHC's Avatar
Thanks Ron, appreciate it man..!
Old Sep 16, 2010 | 11:13 AM
Thanks!!
drtysoufchevy
Suspension & Brakes
54
Jan 28, 2019 07:19 PM
hachilovr
Aug 9, 2018 04:07 AM
spectastic
Honda Civic (2001 - 2005)
Feb 22, 2013 09:44 AM
rick_rabies
Oct 28, 2010 04:17 PM
henwon
Suspension & Brakes
Aug 26, 2010 07:03 PM
