hub bore diameter?
Old Sep 15, 2010 | 06:02 PM
gosu08's Avatar
Default hub bore diameter?
I am getting a piece fabbed for my wheel stand. I just need to confirm info that I have. I searched but only could find 4 lug 4x100 integras.
What is the hub bore diameter for our 5 lug USDM ITR's? Specifically I need 2000 USDM ITR but feel free to post up both JDM and USDM for others when they search.
I've seen people say its 56.1 and others 64.1.
Thanks
Old Sep 15, 2010 | 07:40 PM
BlueIntegraBoy's Avatar
Default Re: hub bore diameter?
64mm
Old Sep 17, 2010 | 01:54 AM
Black R's Avatar
25 Year Member
44300-S5A-008
itr front wheel bearing
markings on center section: NTN AU0907 JAPAN NL
markings on the dust shield: BF5759E 2.4 NOK
~79mm outer diameter
~43mm inner diameter
~38mm outer casing thickness
~41mm center section thickness
*so if you're looking for the diameter of the center of the hub - that goes inside the bearing, it's 43mm.
__________________
Old Sep 17, 2010 | 03:52 AM
Ausmith's Avatar
64.1
94allmotor
Mar 16, 2011 12:47 PM
TerribleToo
Mar 5, 2010 01:08 PM
NsX_CrX
Jun 14, 2006 09:16 PM
Redline96LX
Oct 19, 2005 03:19 PM
boostedsol
Dec 26, 2003 06:26 PM
