*d16z6 built for boost* vitara turbo built sohc for sale!!!
Old Sep 15, 2010 | 01:39 PM
splatterpaintdc's Avatar
Default *d16z6 built for boost* vitara turbo built sohc for sale!!!
d16z6 block and head
~100k on stock head
Block bored .040 over 76mm vitara pistons
FJ distributors spec R rods
ARP headstuds
ARP rod bolts
ACL race rod and main bearings
Brand new OEM oil pump
New OEM water pump
king thrust washers
New OEM timing belt
ALL new gaskets top to bottom
stage 4 6 puck clutch good for 350+ wtq
an 8lb lightend flywheel
have a 98 ex trans with slight grind in 3rd i will throw in with it.
650 obo for all! perfect winter project... or quick fix to the right person.
WONT COME WITH THROTTLE BODY OR INJECTORS
ONLY PROBLEM IS THE MOTOR NEEDS TO BE REHONED AND NEW RINGS NEED TO BE PUT IT.. I HAVE BRAND NEW RINGS FOR IT THE OLD ONES GOT WASHED OUT FROM RUNNING RICH AS HELL...
CONTACT IF THIS INTERESTS YOU!!!
14143266865
Old Sep 15, 2010 | 04:33 PM
ilikejesus's Avatar
Default Re: *d16z6 built for boost* vitara turbo built sohc for sale!!!
pmd
taytay
Jan 8, 2012 09:57 PM
BrakeDanceJ
Aug 26, 2010 07:28 AM
JDMBoostedDA
Oct 9, 2009 11:14 AM
adim
Aug 26, 2009 04:26 PM
KooK
Dec 16, 2005 02:51 PM
