FS: H23 VTEC SETUP SIICKK!! (714) $500 ASAP
2000 Euro Type-R H22 Head (OEM TYPE R PORT & POLISH SUPER CLEAN!!)
includes cams, valvetrain, cam caps, and everything..
H23A1 Short Block (Very slight minor scratched lines, needs to bored & honed to new piston spec which is .5mm over)
Comes with ALL NEW:
H22A1 87.5MM Vtec Pistons w/ Pins
ACL Bearing Kit
ARP Rod Bolts Kit
H23A1 Rods
H23A1 Crank (Newer;Good Condition)
Basically just need to be bored & honed to spec for the installation to it's new .5mm over pistons!! Was quoted about $300 to bore, hone & micropolish/balanced the newer h23 crank from RS Machines! Looking to get just $500 FOR THE WHOLE SETUP!! Hate to see it go.. was going to do my H23 H2B VTEC setup. Moving out of state.. everything has to go! Give me a call at (714) 363-7042. Everything is in VERY GOOD CONDITION. No dirty shitt.. very clean!!
I forgot the exact clearance on the FRM.. how thick it really was. But I know for sure it should be able to still have enough FRM material in it for a .5 over. I think the FRM was like .7+ or something like that, forgot it's been a while.. that's why I went with the .5 in the first place. Please correct me if I'm wrong.
.5mm over stock bore is fine.
I had my H22 machined by Bisimoto like that and he said its ok.
Ill be running 87.5mm pistons (type-s)
Ill be getting that head this weekend bro.
Ill text you today
Ill text you today
Ill text you today
Ill text you today
shortblock comes complete (but torn apart HAS OIL PAN & ALL THE LITTLE PARTS)
for shortblock comes with new:
87.5 h22a1 pistons w/ pins
ACL bearings kit
ARP rod bolt kit
Newer H23 crank
Newer H23 rods
dam got drunk yesterday.. threw up.. finally found my phone but no battery in it?? WHAT!!?!? lol IM me for contact for now
BUMP!!
