93 integra wont start
Old Sep 15, 2010 | 11:33 AM
armitla08's Avatar
Default 93 integra wont start
my buddys motor blew up and we put a different one in it and it wont start. we changed all the old parts to the new motor and were not getting spark. sometimes it will but it will be faint. changed wires, got a diff dizzy, ground down all grounds.. what possibly could be going on?
Old Sep 15, 2010 | 03:19 PM
delsolproblems's Avatar
Default Re: 93 integra wont start
Did you replace the cap, rotor, coil and ICM with the distributor or use the old ones? If you replaced them, were the new ones new in box? Test your grounds with a meter set to resistance. Make sure there is zero resistance between the valve cover and the battery negative post. Also, make sure your battery is charged.
philosofy1
Feb 23, 2010 09:46 PM
lilo_goki
Sep 18, 2009 10:44 AM
joyrider58
Jan 1, 2009 10:23 PM
lilgreenlude93
Apr 7, 2004 10:20 PM
93 Integra NC
Jul 2, 2001 08:09 PM
