? valve lash when degreeing cams
Old Sep 15, 2010 | 10:43 AM
mhewitt's Avatar
Default ? valve lash when degreeing cams
im trying to degree in my pro2's ad i have read to degree them with valvelash at .000 but have also seen where people were doing it at normal valvelash of .007, .008. what is the correct way to do it because i dont want to have them adjusted incorrecty due to valvelash
kyden's Avatar
Default Re: ? valve lash when degreeing cams
i've always done it at 0 lash.
Old Sep 16, 2010 | 10:09 AM
speedoptions.ca's Avatar
Your valve lash(clearance) should be at 0.007"(cold;intake)
and 0.008" (cold, exhaust)
DO NOT put valve lash at 0. When they get hot and expand you will run the risk of seizing a cam, which will lead to engine failure and a costly rebuild.
Old Sep 16, 2010 | 10:12 AM
kyden's Avatar
he's not talking about doing a valve adjustment. he's degreeing cams.
Old Sep 16, 2010 | 10:51 AM
Honda Bull's Avatar
Degree them with .000-.001" lash. Set lash back to Skunk2's recommendations (probably .007-.008" intake / .008-.009" exhaust) in order to run the engine though or you'll run into some problems, as mentioned.
Racewerkz
Jan 26, 2011 07:55 AM
Absentmind
Nov 8, 2005 02:19 PM
Yusuke
20
Feb 15, 2005 02:45 AM
civicboy95
Nov 18, 2001 02:51 PM
