please any info high compression 13.1 +turbo octane enough?
Old Sep 15, 2010 | 03:33 AM
slowcrx954's Avatar
Default please any info high compression 13.1 +turbo octane enough?
heres a link to my build,https://honda-tech.com/forums/all-motor-naturally-aspirated-44/help-me-make-more-power-dyno-inside-2796992/
i really want to boost my set up,but octane really worries me.will e85 cut it?
please anyone,tuners,someone with any experiance!
cams can be changed as i have a set of b16 and gsr.can pick up a set of type r's
Old Sep 15, 2010 | 08:57 AM
unusual71's Avatar
Default Re: please any info high compression 13.1 +turbo octane enough?
it all boils down to cylinder pressure. all other things equal, including boost level, then a higher compression ratio will lead to higher cylinder pressure. that means you'll make more power on less boost. However 13:1 compression is quite high even for a naturally aspirated engine so you would be limited to only running a small amount of boost. that being said it would be incredibly difficult to tune well without detonation. I would also be worried about the shape of the piston creating hot spots which could lead to pre-ignition.
bottom line, most people here will say don't do it and personally I am one of them. If you need to go boost then sell this motor or rebuild it with some 9/10:1 pistons.
Old Sep 15, 2010 | 03:01 PM
slowcrx954's Avatar
thanks alot,not what i wanted to hear.but truth/
gs1gsr
Aug 19, 2012 05:42 PM
imzjustplayin
Dec 27, 2009 12:46 PM
Coppertop
Aug 25, 2005 12:18 PM
philo
Nov 29, 2002 11:31 PM
