TB Size oem ITR JDM 98 spec
Old Sep 15, 2010 | 01:12 AM
Rishiras's Avatar
Default TB Size oem ITR JDM 98 spec
Guys,
What would be the size be of a JDM ITR 98 spec Throttle body?
Any link with info would be appreciated to confirm sizes
Old Sep 15, 2010 | 03:32 AM
Just a n00b's Avatar
Accident Prone
Default Re: TB Size oem ITR JDM 98 spec
according to this thread, it's 67mm. hope that helps
Old Sep 15, 2010 | 04:36 AM
heel_touge's Avatar
haha 67!!! no way
you call it by the size it is past the butterfly, 62mm
Old Sep 15, 2010 | 06:34 AM
Accident Prone
whoops turns out I was mistaken. it is 62mm
http://passwordjdm.com/JDM-ITR-Throt...P1704C213.aspx
Old Sep 15, 2010 | 07:34 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
i thought it was 65.. i could be wrong
Old Sep 16, 2010 | 07:28 PM
JR_98spec-0315's Avatar
+1
http://www.ipgparts.net/blog/tag/oem-itr-throttle-body/
Old Sep 19, 2010 | 09:34 AM
Rishiras's Avatar
So If ITR is 62mm, would a upgrade be better to 65 mm or 68mm.
Mods are simple, Mugen I/E/H and cam gears adjusted
Old Sep 19, 2010 | 12:48 PM
FlewByU352's Avatar
Lol I thought it was 68MM. What is the GSR throttle body size?
Old Sep 19, 2010 | 09:23 PM
S2kRyan's Avatar
B-series/H-series= 60mm
ITR=62
EuroR H-Series= 62mm
S2000= 62mm
D-series= 58mm
Old Sep 20, 2010 | 12:00 AM
FlewByU352's Avatar
^ good info right there. I knew the ITR was 2MM bigger than the other B series but IDK why I though 68MM. Maybe because of the aftermarket throttle bodies are that size? IDK
Old Sep 26, 2010 | 07:55 AM
Rishiras's Avatar
what size would the CTR be then , B16B, that is not listed on the link from IPG.
Old Sep 26, 2010 | 01:00 PM
DC4 Rasta's Avatar
is there a difference between the 96-97 spec R and the 98-01 spec R?
Old Sep 26, 2010 | 01:24 PM
BlueIntegraBoy's Avatar
Most likely 62mm
Old Sep 27, 2010 | 01:34 PM
S2kRyan's Avatar
Originally Posted by BlueIntegraBoy
Most likely 62mm
Correct CTR got the same IM and TB as the ITR
Rishiras
Jul 21, 2010 12:11 PM
ORANGE EF
Mar 1, 2009 03:15 PM
ExplicitSpeed360
Nov 26, 2005 05:44 AM
Beave0101
May 20, 2003 12:03 AM
bikeboy80
Nov 5, 2002 06:33 AM
