clutch help....
Old Sep 14, 2010 | 09:54 PM
92sully's Avatar
Default clutch help....
i need some help on my 92 prelude...i have the 2.3 litre and my clutch just wont engage...the slave cylinder is working and the fork is moving back and forth...im positive i have bleed them completely....now when the car is on the car can not go into gear why?
Old Sep 15, 2010 | 04:34 AM
nus_dogg's Avatar
Default Re: clutch help....
Have you check your tranny fluid? One time I had water mixed inside with my MTF and my car wouldn't go into any gears at all.
Old Sep 15, 2010 | 07:04 PM
92sully's Avatar
Yes, i filled it up before i started the engine up for the first time...the clutch just wont engage for some reason
Old Sep 16, 2010 | 08:59 PM
civic=goodgasmileage's Avatar
having the same problem with my buddy's lude. it's an 2000 prelude . he let a friend drive it and he stalled the car on first gear. and all of a sudden clutch is soft and wouldn't go into no gears at all. changed out MC and SC. got pressure back and clutch is still soft and still wouldn't go into gear. changing out who clutch. hopefully it is he problem.
Old Sep 16, 2010 | 09:42 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
What happens when you start in first gear and let the clutch out?
Old Sep 17, 2010 | 06:47 AM
sde780's Avatar
did you line up the clutch with the alignment tool when you aligned it?
Old Sep 17, 2010 | 08:19 AM
Kelly66218's Avatar
I understand the car go thru the gears from neutral with it off. Only binds while engine is on.
@5spd- It'll work to get the car in gear,but more than likely if he starts in 1st he'll have a hellof a time geting it into 2nd/3rd/ and back down. I have dealt with something of this magnatude with mine. Also the car will act like it's clutchless, a pain in the ***.
Honda MTF is the best. I don't know why? I tryed different ones too.
3 things I can think of linkage probs, or Sync problems and I have a to also agree with sde780 that if the clutch is not aligned or a warped flywheel you will also experience difficulties, getting into gear.
snzh22
Apr 29, 2008 09:22 AM
2wheelhunter
Aug 30, 2006 07:32 PM
hellrsnCL
Aug 10, 2005 08:29 AM
dexy
Jan 11, 2005 09:53 AM
erikgsr
Apr 6, 2003 12:03 PM
