dizzy wiring
Old Sep 14, 2010 | 07:50 PM
h22 mean green's Avatar
Default dizzy wiring
hi im a newb and i have some problems with a swap that im doing its a f20b blue top into a 96 accord. the dizzy plugs dont match at all the car is obd2 external coil and the dizzy that came with the f20b is internal coil obd2 and i tried using the stock f22 dizzy but no luck at all and i tried swapping the internal parts of the f22 into the f20b and no luck. any advice? thanks for looking please wait 2 seconds for an uncompressed image, or press Ctrl+F5 for original quality page
Old Sep 15, 2010 | 04:17 AM
nus_dogg's Avatar
Default Re: dizzy wiring
You'll need to source a OBD2 JDM H22A Distributor, so you can be able to plug in the dizzy connectors to your engine harness I believe.
I'll let other chime in on this one as well.
Old Sep 21, 2010 | 06:49 PM
still no luck i think the problem ist the wiring of the car has 3 plugs one has two wire and the other one has 4 and the other ones is for the external coin .....so i need to wired the dizzy to the f20b ecu but dnt now the pin out of the ecu or dizzy someone has a diogram or something that would help me ou??? thanks for looking
Greenflashlight
Apr 7, 2012 07:24 AM
Ct93CB7
Jan 9, 2011 05:29 PM
ozmannnnn
Nov 18, 2010 05:33 PM
bukhumlae
Aug 1, 2008 09:30 PM
