HELP: acura rsx oil pan
Old Sep 14, 2010 | 06:11 PM
DC5TYPE-SsS's Avatar
Default HELP: acura rsx oil pan
ACURA RSX TYPE-S 04
i have a huge problem....my oil pan drain hole is script!.... or maybe its not?
cause the oem screw was script so i had bought a replacement screw at auto
zone. I was wondering if the oem screw is longer ? because it seems like the
auto zone screw is shorter ? or maybe it is and i need a new oil pan??? help help
help....................
Old Sep 15, 2010 | 06:28 AM
turboteg2nv's Avatar
Default Re: HELP: acura rsx oil pan
Take it to the dealership. You're too incompetent to change your own oil.
Old Sep 15, 2010 | 10:52 AM
hawaiiancb74's Avatar
lol wow, i think you mean stripped, none the less the length of the oil plug doesn't really matter as much as long as there is plenty of thread on it to become secure. now what happened is that you messed up the oil pan and not the plug.. the plug is rarely the culprit in this case..so take that plug back to auto zone, and take your car to a dealership or a trusted mechanic to have the pan repaired or replaced.. only drive the car if it has oil in it, if it doesn't have oil in it, because you cant seal the hole in the oil pan drain then you need to have it towed to a repair facility. and sorry but more than likely this is going to cost you a lot of money to fix.
Old Sep 19, 2010 | 08:35 AM
jdm91CrxSi's Avatar
you can spend $80-90 On an oil pan, or $40-$50 on a Tap set
Old Sep 19, 2010 | 10:12 AM
Navy_CRX's Avatar
If it makes u feel better my wife used an impact gun on hers and stripped it out. I told her to use the gun to take the bolt out and she decided to use it to put it back in. Oh well **** happens. New oem pan is 200 on ebay. Good luck.
Old Sep 19, 2010 | 12:09 PM
yeah new pan is around 200 bucks for a type s, i know shops in the past that have dropped the sub frame and dropped the pan and then welded in the threads and re tapped the pan.. but its still not cheap.
Old Sep 20, 2010 | 04:54 AM
If you tap the oil pan, I would remove it first to make sure you don't get any metal shavings inside the engine block.
Hahahahaha. Oh man that's funny. But props to your wife for doing her own oil change Gotta start somewhere..
I would just buy a used oil pan on K20a.org or clubrsx.com for $90-100 and install that, call it a day. That's probably you're easiest/cheapest solution.
Old Sep 20, 2010 | 02:37 PM
WhiteOnRice's Avatar
Remove, try tapping. If it doesn't work out, buy a used like turboteg suggested.
Old Sep 20, 2010 | 10:09 PM
nawhhhh found the problem......... it was the screw..... auto zone screw was tooo small and didnt come with a washer...so i went to acura and fixed the problem
Old Sep 20, 2010 | 10:10 PM
i know how to cchange my oil....
Old Sep 20, 2010 | 10:12 PM
thanks for the help guys!^^^^^^^^^^^^^^^^^^
cyn7
Honda Civic (2001 - 2005)
Nov 28, 2011 09:13 PM
z4nd
27
Oct 2, 2010 09:39 PM
tamadrumr88
Dec 24, 2009 04:34 PM
_Cyclone_
20
Feb 10, 2005 05:47 AM
92preludeSI
Mar 10, 2003 07:33 PM
