EG hatch with a z6: tach messing up/transmission noise
Old Sep 14, 2010 | 10:21 AM
codrulz's Avatar
Default EG hatch with a z6: tach messing up/transmission noise
i have EG hatch with a z6. i just put in a new stock clutch & a "rebuilt" transmission (manual). i think the transmission has had some work because its stamped A000 but has ex gears & its VERY clean on the outside. my problem is that there is a whinning noise from the transmission side while going down the road but it goes away if i let off the gas & it doen't do it at itle. the other problem is that when i accelerate hard the tach will jump some , not terribly , but its definatly noticeable. the tach never did this before.
so anybody got an idea of whats going on here?
-thanks
Old Sep 14, 2010 | 05:35 PM
codrulz's Avatar
Default Re: tach messing up/ transmission noise
bump. could the tach problem be because im using a cx speed sensor rather then a ex ?
Old Sep 14, 2010 | 05:42 PM
Former User's Avatar
The tach gets its signal from the igniter unit inside the distributor. Have it tested.
Does the transmission noise go away when the clutch pedal is pushed to the floor?
Old Sep 14, 2010 | 05:44 PM
EJeff8's Avatar
Noise with clutch pressed in = Throw out Bearing, most likely.
Noise with Clutch let out = Input shaft Bearing, most likely.
Old Sep 14, 2010 | 05:52 PM
codrulz's Avatar
the dizzy is pretty new so i would think its fine. as far as the noise it does not do it idle . only when im giving it gas but goes away if i let off
Old Sep 14, 2010 | 05:56 PM
Default Re: EG hatch with a z6: tach messing up/transmission noise
Make sure the blue tach wire attached to the igniter unit is clean, tight, and undamaged.
Old Sep 14, 2010 | 06:01 PM
codrulz's Avatar
^^^ okay thanks i will check that tommorow!
Old Sep 14, 2010 | 06:02 PM
Does the clutch seem to be slipping?
Old Sep 14, 2010 | 06:04 PM
codrulz's Avatar
i dont think so? this is only my second car and dont know the signs of a clutch slipping.
Old Sep 14, 2010 | 06:07 PM
When attempting to accelerate, do the engine rpms rise high without the car moving as fast as you'd expect?
EJeff8's Avatar
^Revs up at random spots while accelerating and seems like it doesn't have the power that it should at certain rpms...
Old Sep 14, 2010 | 06:10 PM
codrulz's Avatar
the rpms in relation to the speed seem normal ( atleast i think lol)
Old Sep 14, 2010 | 06:11 PM
Was the flywheel resurfaced or replaced when the new clutch was installed?
Old Sep 14, 2010 | 06:13 PM
EJeff8's Avatar
^So, while you're accelerating the rpms just don't all of a sudden rev while you're foot never left the gas or touched the clutch?
This would be the signs of a very bad slipping clutch though.
Old Sep 14, 2010 | 06:14 PM
codrulz's Avatar
no it wasnt. which probably wasnt smart of me but im only 17 and dont think sometimes haha
Old Sep 14, 2010 | 06:17 PM
codrulz's Avatar
no the tach only jumps when i accelerate hard. and seems only past 4k ( so when its in vtec?)
Old Sep 14, 2010 | 06:20 PM
EJeff8's Avatar
That is called slipping...
Old Sep 14, 2010 | 06:25 PM
codrulz's Avatar
great... why would it slip if its a new clutch?
Old Sep 14, 2010 | 06:27 PM
EJeff8's Avatar
Did you replace the whole kit or just the clutch plate?
Old Sep 14, 2010 | 06:30 PM
codrulz's Avatar
everything. & i had someone thats been working on cars forever check it out.
Old Sep 14, 2010 | 06:33 PM
EJeff8's Avatar
Hm. We might need to wait for Ron, I'm at a wall.
Old Sep 14, 2010 | 07:14 PM
codrulz's Avatar
can you tell me if the clutch is adjustable & if the clutch slave cylinder is not bled right could this cause this problem? also how tight should the clutch pedel feel with a oe style cluch?
Old Sep 14, 2010 | 07:19 PM
EJeff8's Avatar
Clutch engagements can be adjusted, so I really wouldn't know. I'm at a loss at this point, I wouldn't want to start guessing things.
Old Sep 14, 2010 | 07:21 PM
As you are releasing the clutch pedal, how high does it rise before the clutch is fully engaged?
I don't think a clutch hydraulic system problem would cause the whining you describe.
If the clutch is truly slipping, then the flywheel that was not resurfaced may be the problem.
Are you sure the noise is not coming from one of the drive belts?
Old Sep 15, 2010 | 04:43 AM
codrulz's Avatar
what is the break in period (miles) that should be driven on a rebuilt tranny before actually really "getting on it?
