Timing Issues on my LS
Old Sep 14, 2010 | 09:47 AM
Dual Cam Killer's Avatar
Default Timing Issues on my LS
Ok so ive tried and tried and tried to get this thing into perfect timing, no luck. When the cams are in perfect alignment, the crank looks as to be off ever so slightly. The exhaust tone has the very very very slightest studder, is this gonna hurt the engine any time soon? If i wasnt a mechanic, i would barely be able to hear the studder. Car runs smooth, power is there, im just afraid of internal damage. Any positive input will be greatly appreciated. Thanks fellas
Old Sep 14, 2010 | 01:29 PM
mouab18c1's Avatar
Default Re: Timing Issues on my LS
The timing should be on TDC for quality performance.
Old Sep 14, 2010 | 02:06 PM
dntnedvtec's Avatar
If you were a machanic, you would have got it down to the nuts. If the crank is off, Just remember, you should be at 16 deg BTDC. Adjust your distibutor till your 16 BTDC by turning your distributor.
Old Sep 15, 2010 | 06:41 AM
dpetro1's Avatar
uh...cam timing and ignition timing are two different things.
OP, there must be something preventing you from setting the timing correctly. either 1. you are doing it wrong or 2. you have the wrong parts (t-belt, water pump, cam gear). im betting on #1 though.
remove the belt, set everything to tdc and reinstall. repeat until the belt is on and everything is lined up properly
Old Sep 15, 2010 | 03:18 PM
dntnedvtec's Avatar
Your right.
I thought he was setting his timing. My bad.
98bucket
Nov 21, 2010 03:57 PM
EX-T
Jan 21, 2009 04:16 PM
JDMTurboCivic11
May 1, 2005 08:32 PM
Jamison
May 21, 2002 05:58 AM
neumonik
Mar 10, 2002 04:41 PM
